May 16, 2018 at 9:20 pm
blank
SubscriberHi,
I know Ansys allows using a dynamic frictional formulation for the coefficient of friction in Explicit Dynamics models, is it possible to use this formulation for the friction coefficient in static structual models too?
I mean can i use the triad: friction coefficient ,dynamic coefficient of friction, exponential decay coefficient to define friction for a contact pair in a static structual model?
Thanks
May 16, 2018 at 9:36 pm
sk_cheah
SubscriberYou could take a look at friction options offered by CONTA174. You would likely have to insert a command snippet to access it.
Kind regards,
Jason
May 17, 2018 at 4:19 pm
blank
SubscriberThanks for the swift reply.
I did have a look at the options you linked, you are right ,command snippet is propably the way.
Still if anyone knows a way to do this through the GUI in workbench like you can with explicit dynamic models please let me know , I don't really feel comfortable writing my own friction law snippet yet
May 17, 2018 at 10:02 pm
sk_cheah
SubscriberGive APDL script a try. Start out with a simple model with known solution, you can then troubleshoot your script to gain confidence.Â
For your specific problem, the snippet is entered at the frictional contact. Note the dynamic friction value (MU) is entered:
Next, the content of the snippet itself:
et, cid, 174
mycid = cid
rmodif, cid, 21, 4.555, 0.11729
RMODIFÂ help describes the real constants of #21 and the next one #22Â of CONTA174 as respectively Static/dynamic ratio and Exponential decay coefficient.
Kind regards,
Jason
- The topic ‘Dynamic frictional formulation for the coefficient of friction’ is closed to new replies.
6535
1311
