TAGGED: ansys-electronics, ansys-maxwell-3d, transformer
June 14, 2022 at 4:32 pm
grigorios.sergentanis
SubscriberHi all,
I have simulated an interleaved transformer in 3D, and I would like to create a 2D graph of the MMF force versus the distance, as is done in the images below. I tried to plot along a polyline, but it seems to not do the trick. Has anyone ever done this and could share how to do it?
Man thanks for any help. -
August 1, 2022 at 10:51 am
NKC
Forum ModeratorHi Grigorios,
Does the reference image you are showing plotted from maxwell?
I think this is not plotted directly from Maxwell and is shown like that for illustration purposes.You can get the MMF values at different distances by drawing a polyline as you are already doing that.
Navya
- The topic ‘Drawing the MMF graph of a transformer in Ansys Maxwell 3D’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1338
1188
