3D Design
3D Design
drawing sheet different from the 3d model
    • cbur
      Hello, I'd like to let you know about a BUG that one of our customers had: The drawing sheet doesn't match the 3D! The "brush" components are not located in the right place and are not oriented in the right way (see photos 1 to 4). The problem was solved by converting to Step and redoing the drawings, but this is surprising coming from SpaceClaim, which is supposed to represent the 3D in the drawing... do you know where this is coming from? have you ever encountered this type of problem? I can provide you with the file privately for study if you wish.
      Sincerely
    • Devendra Badgujar
      I have not seen this before, will need to check and get back to you on this.
      Devendra
  • The topic ‘drawing sheet different from the 3d model’ is closed to new replies.
