July 7, 2023 at 7:29 am
Akankhya Patro
SubscriberI am doing simulation of submarine one quarter side of it with following boundary condition:
inlet
outlet
four wall : symmetry
giving Y+=50
Turbulence modeling =k- epslion realizable model with enhaced wall treatment
I need to find out drag coefficent. my velocity profile is matching with the research paper but my drag coefficent is not matching though my graph is converging can anyone please suggest what changes i need to make.
July 7, 2023 at 8:17 am
SRP
Ansys EmployeeHi,
Check that your mesh is of sufficient quality and properly resolves the boundary layer near the submarine’s surface. Use a mesh refinement study to verify that the drag coefficient is not significantly affected by mesh size or grid resolution.Check the y+ value after the computation again as the real flow field will develop during the simulation and a remesh might be necessary.
Thank you.
- The topic ‘drag coefficent not matching of submarine’ is closed to new replies.
3487
1057
1051
955
917
