October 23, 2024 at 5:02 pm
bpedar
SubscriberHello,
I have modeled a 14 pole rotor rotating at 500 mechanical RPM in the condition of no excitation in the windings. Then created the following output variables to change the coordinate system from 3 phase to alpha_beta for the stationary and dq for rotating. Expecting to see constant values in dq frame.Â
the FLD_srf is flux linkage in alpha and FLQ_srf is the flux linkage in beta coordinates and the fld and flq in rrf are in dq coordinates. the number 7 is multiplied to mechanical angle to give back the electrical angle. the graphs recieved are:Â
as can be seen the alpha beta coordiante are as expected but dq is not and is producing a wave with twice the frequency of electrical. Appreciate anyone helping in solving this issue.Â
November 19, 2024 at 4:17 pm
Tamami Yamanaka
Ansys EmployeeHello,
Moving1.Position, cos(Theta_E) and sin(Theta_E) against time in the XY plot to check that they show the expected periodicity and linear behaviour.
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- Calc Error in Field Calculator after PyAEDT Analyze
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Rectangular Coil in Maxwell for WPT using solid block
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
4512
1494
1386
1209
