Electronics
Electronics
Hfss 3D pcb via capped and filled with epoxy
    • kagankarakusx
      Hello, I transferred a pcb from altitum to ansys hfss3d layout as edb, I want to convert this via to a capped via and fill an insulating epoxy into the hole when necessary, how can I do this?
      Via in Pad PCB Design | MacroFab
    • Atsuko Kikuchi
      Such vias cannot be configured in HFSS 3D Layout. Since it is possible in HFSS, I recommend converting the design to HFSS model and simulating there.
      How to export a design from HFSS 3D Layout to HFSS 3D Classic:
       1. define an HFSS Solution Setup in the HFSS 3D Layout design
       2. right click on the HFSS setup name in the Project Manager window and select Export -> HFSS Model...
[bingo_chatbox] ; jQuery(".user-experience-select").select2({ data: data, minimumResultsForSearch: -1, escapeMarkup: function(markup) { return markup; }, templateResult: function(data) { return data.html; }, templateSelection: function(data) { return data.text; } , dropdownParent: jQuery(".user-exp-outer") }); jQuery(".user-experience-select").select2("val", "https://innovationspace.ansys.com/ais-experiences/"); var timesClicked = 0; jQuery(".user-exp-outer").click(function(e) { timesClicked++; e.preventDefault(); if (timesClicked%2==0) { //run second function jQuery(".user-experience-select").select2("close"); } else { //run first function jQuery(".user-experience-select").select2("open"); jQuery(".user-exp-outer").addClass("active"); e.stopPropagation() } }) jQuery(document).on("click", function(a) { if (jQuery(a.target).is(".user-exp-outer") === false) { jQuery(".user-exp-outer").removeClass("active"); jQuery(".user-experience-select").select2("close"); timesClicked = 0; } }); jQuery(".user-experience-select").on("select2:select", function (e) { if(e.params.data.ais=="true"){ window.open(e.params.data.id,"_self"); } else{ window.open(e.params.data.id); } }); });
