DPM iteration freezes
    • Oracle
      I run a VOF and DMP/DEM simulation of particle sedimentation. I inject particles with the fluid in a tank filled with air.
      For unknown to me reason my simulation freezes at: "DPM Iteration ...." message. Even when left for 12 hours nothing changes. It happens at different times into the simulation. I tried two options for particles: DPM and DEM, both freeze randomly.
      I run parallel simulation in Fluent 15.0.
      Had anyone faced the same issue? What could be the problem?
      Best regards, Marta
    • DrAmine
      First test with newer version. Second try reducing number of parcels. Keep in mind particles ignore free surface.
    • Oracle
      I did notice that particle move between free surface. That is another issue. I m looking for suitable UDF to force particle to bounce off the free surface - it was your suggestion in my other post.
      What kind of UDF for DPM should I write: drag, law, property? I am going through UDF manual and there is no example close to my case.
      Best regards,
      Marta
  • The topic ‘DPM iteration freezes’ is closed to new replies.
