April 27, 2022 at 5:32 pm
Barbol
SubscriberI apologise if this question has been asked before, some things before I explain my issue:
Running a 2D bubbing fluidised bed simulation with DDPM, and injecting with unsteady file injection method.
My question is whether the "diameter" refers to particle diameter (and Fluent in the background calculates a parcel diameter), or whether it is the parcel diameter. Or does it even matter as DDPM does not deal with collisions (apart from walls).
If it is the parcel diameter how does one go about conversion from particle diameter to parcel diameter? I would guess you could make a calculation based on the knowing that 2D parcels in fluent a Cylinders and going from there.
Thanks in advance
Sam
April 28, 2022 at 1:49 pmRob
Forum ModeratorParticle diameter in the Injection properties panel. However, you want the Eulerian (possibly Mixture) model here, not DDPM.
Viewing 1 reply thread- The topic ‘DPM Injection, “Diameter” Meaning’ is closed to new replies.
3487
1057
1051
955
917
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
