October 23, 2021 at 8:57 am
Sayantan Biswas
SubscriberDear All,
I'm working on air-water two fluid system using DPM method. The darg force is implinted via UDF. I want to store the DPM drag force magnitude in a UDMI. What modification it required to store 'drag_force' in an UDMI?
Drag UDF as follow:
# include "udf.h"
# include "dpm.h"
DEFINE_DPM_DRAG(particle_drag_force,Re,p)
Thread *t= P_CELL_THREAD(p); /*not sure about this line*/
cell_t c= P_CELL(p); /*not sure about this line*/
real dia, etov;
real adrag, bdrag, cdrag, drag_force;
dia=0.005;Â Â /* bubble diameter */
/* to compute Eotvos Number */
etov=9.81*994.38*(dia*dia)/0.072;
/* to compute the drag coefficient */
adrag=24.0*(1+0.15*pow(Re,0.687))/Re;
bdrag=8.0*etov/(3.0*etov+12.0);
if(adrag>bdrag)
{cdrag=adrag;}
elseÂ
{cdrag=bdrag;}
drag_force=(18.0*cdrag*Re)/24.0; /*this term I want to store in a UDMI*/
C_UDMI(c,t,0)=cdrag;
C_UDMI(c,t,1)=drag_force;
return (drag_force);
UDMI requires to access cell and thread, how do I define in DPM simulation?
October 25, 2021 at 10:32 amRob
Forum ModeratorAre you wanting the DPM effect on the fluid, or the fluid effect on the particle? https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/flu_udf/flu_udf_sec_define_dpm_body_force.html may give you some hints.
October 25, 2021 at 11:21 amDrAmine
Ansys EmployeeJust not use hybrid parallel method and it would work (as hybrid might require some more lines to avoid co-current processes writing in the same memory). I have a feeling you are just using the UDF without really understanding the whole issue: is this correct?
Viewing 2 reply threads- The topic ‘DPM drag force store in UDMI’ is closed to new replies.
