December 25, 2024 at 3:38 pm
dmitarenigma
SubscriberHello. I have a problem when I am trying to update Desing of Experiment data under Response Surface. I get this message: (DP 0) The Design of Experiments component in Response Surface could not be updated as some required data has not been provided. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell in the Project Schematic. I made a model in solidworks, then imported the model in ansys where I selected the parameters and when I tried to update "Desing of Experiment" I get that message. Can someone tell me what is the problem? Also I tried to optimize simple cube model to see if maybe the problem is in my model, but I got the same message.
December 26, 2024 at 3:27 pm
peteroznewman
SubscriberClick on the Parameter Set and show the input design variables that have been defined.
December 29, 2024 at 3:05 pm
dmitarenigma
SubscriberI solved the issue. Forgot to define output parameters.
6785
1331
1147
