March 14, 2022 at 1:54 pm
SCL
SubscriberWhile calculating waveguide modes, you can set up an input beam (diameter, lens NA, distance from focus) and calculate the overlap & power coupling.
Does the power coupling result incorporate reflection due to index difference, if I set the refractive index of the input beam to 1?
March 21, 2022 at 11:09 pmGuilin Sun
Ansys EmployeeYes, it does consider the index difference from the mode. However, it might be not exactly the same as you do the simulation to extract the power coupling .
Viewing 1 reply thread- The topic ‘Does “power coupling” include reflection due to index difference?’ is closed to new replies.
3862
1414
1221
1118
1015
