March 26, 2019 at 7:34 pm
Yerucham100
SubscriberI am performing a CFD simulation on a wind turbine blade, I noticed that I get better results when I remove the inflafion layer but this makes little sense to me. Why is the inflation layer negatively affecting my results? -
March 26, 2019 at 11:41 pm
peteroznewman
SubscriberHow do you quantify the quality of the results?
Please show the mesh metric of skewness for the mesh with and without the inflation layer.
March 27, 2019 at 6:30 am
Yerucham100
SubscriberBy quality I mean that the torque calculated is closer to the actual value but now that you mention it, the skewness improves when I remove the inflation layer but the improvement is very small in my opinion compared to the torque -
March 27, 2019 at 7:59 am
Keyur Kanade
Ansys Employeewhat viscous model you are using?
ke ewt and kw sst will require inflation layer.Â
March 27, 2019 at 10:22 am
Yerucham100
SubscriberI am using kw sst viscous model -
March 28, 2019 at 7:36 am
Keyur Kanade
Ansys Employeekw sst will require inflation layer.Â
what is mesh orthogonal quality?
min orthogonal quality should be more than 0.1.Â
https://www.youtube.com/watch?v=AzvPxjNyr3w
March 29, 2019 at 11:23 am
Yerucham100
SubscriberThe minimum orthogonal quality is about 0.03 -
March 29, 2019 at 3:16 pm
Forum Moderator With mesh quality down there I suspect it's more the case that the non-inflated model is less skew and so you're seeing a better result. Ie it's not the lack of inflation that's helping, more the reduction in poor cell quality.Â
March 31, 2019 at 12:52 pm
Yerucham100
SubscriberThat could be it, but I now think the correct results I was getting before were pure coincidence because on reducingthe tip speed ratio of the blade from 7 to 5, the torque doesn't go down as expected, the error is significant but when I restore the inflation layer, the torque decreases with tip speed ratio as it should. I think I need further mesh refinement with the inflation layer to get good results -
April 1, 2019 at 7:01 am
Keyur Kanade
Ansys Employeeif this helps you, please mark this as 'is solution' to help others on forum.Â
Viewing 9 reply threads
- The topic ‘Does Inflation layer reduce accuracy in CFD?’ is closed to new replies.
1306
