July 24, 2020 at 6:32 am
PradnyaG20
SubscriberI am a beginner in Ansys and am trying to design a microfluid network. I imported my file in .dxf format in spaceclaim. When I use the command fill and specify the thickness, will the software create a solid/ extrusion of the closed channel profile of the given thickness? If not please help me understand what the fill and extrude commands actually mean and the difference in their funtioning.Â
July 24, 2020 at 1:00 pm
Forum ModeratorMaybe. It'll depend on the geometry. If you can use a different import option as dxf can be unreliable. You may be better off building the model in SpaceClaim from scratch if it's fairly simple.Â
July 27, 2020 at 5:51 am
Keyur Kanade
Ansys EmployeePlease insert some images so that we understand the question in better way.Â
Please check help document for fill and extrude.Â
Please go through some tutorials.Â
https://www.youtube.com/watch?v=S0j_vuBPi-I
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘Does fill command in Spaceclaim create a solid if thickness is specified?’ is closed to new replies.
5849
