March 31, 2019 at 1:05 am
ehkh
SubscriberHi,
I am planning to perform DNS using fluent for turbulent flow in a three dimensional triangular cavity, to do so I understand that I need to use very fine mesh and as a consequence a very large number of cells that could reach 10trillion cells for small geometry.
My question is what's the minimum RAM, CPU and processor required to run the simulation.
Thanks
March 31, 2019 at 5:54 am
DrAmine
Ansys EmployeeA rule of thumb minimum of 2 Bytes per cell for double precision run.
March 4, 2021 at 9:09 am
wcj1n18
SubscriberHi, just looking into something similar. If we are looking to do DNS (which of course requires a very high level of precision), is the double precision on Fluent sufficient? I mean, if it rounds to a given number of decimal places, can this not accumulate to an inaccurate figure after a large number of timesteps? Or can it be assumed that double precision will be sufficient for almost all cases?n -
March 4, 2021 at 9:16 am
Aitor
SubscriberThe error induced by the diffusion of the numerical scheme or the geometry of the mesh will be more important than the one induced by the computer arithmetic.n -
March 4, 2021 at 9:38 am
Forum ModeratorAs comments, your mesh resolution and time step will play a greater role in numerical issues than the solver precision. Good luck getting the compute hardware to run the cell count you need for DNS, KAUST might have enough cores.... https://www.ansys.com/about-ansys/news-center/07-18-17-ansys-saudi-aramco-kaust-shatter-supercomputing-record but it may be a bit ambitious for Ansys Student! n
Viewing 4 reply threads
- The topic ‘DNS using Fluent’ is closed to new replies.
