November 19, 2023 at 2:54 pm
Jason Sum
SubscriberNA
November 20, 2023 at 12:31 pm
Forum ModeratorYou may want to check your direction vector for "up". If z is up it's not [1] in the vector definition!Â
January 20, 2024 at 6:56 am
Jason Sum
SubscriberHi Rob, thank you for the guide.
I have rotated my geometry so that y is pointing upwards to meet the UDF.
Still same errors occur during initialisation. Everything works when I just insert constant velocity for inlet without udf
Sincerely hoped for further advice, Thanks!
January 22, 2024 at 11:25 am
Forum ModeratorI'd have changed the UDF! What is the minimum y value in the domain? Use the Scale tool in Fluent to find out.Â
January 22, 2024 at 1:02 pm
Jason Sum
SubscriberÂ
Yes I have altered the ZREF and LREF according to my building geometry with height (z-axis): 150m and cross-sectional width: 64.4m. For the rest of the UDF, I think they describing the general solving for atmospheric boundary layer in velocity, k and epsilon, so I didnt modify it.Â
#include "udf.h" #define UREF 4.491 // reference wind speed at ZREF #define ZREF 150.0 // height of the building, 2b #define LREF 64.4 // characteristic length, b #define CMU 0.09 //
Or are you referring to the mini. y+ of my mesh domain?
Thank you for help.Â
January 22, 2024 at 1:09 pm
Forum ModeratorNo, what is the minimum y coordinate on the inlet?Â
Before going too much into y+ how confident are you about the ground position and detail? I see far too many thinking y+ is the only mesh metric, and if you have bushes, trees, curbs etc did you also resolve all of those?Â
- The topic ‘NA’ is closed to new replies.
5674
1890
1419
