December 18, 2024 at 9:41 am
mohammedlaminemekhalfia
SubscriberDear ANSYS users ,
I am trying to simulate the dynamic of a rotating disk using Transient Structural, the disk rotate on it's center.
The rotation speed is 100 RPM. so I added a joint (Revolute) and I tried also general ( and kept rotation free on the axis Z). I added a joint because I had to visualize rotation effect.
I added also a fixed support to the center of it's rotation and tried (cylindrical support and all the others).
I had a warning that the supports are not enough + convergence issue.
The step size was 0.0001. and nothingÂ
This disk has the folowing shape:
December 19, 2024 at 11:24 am
harshvardhan.negi
Ansys EmployeeHi,
It seems that you are creating too many boundary conditions. If you have created a revolute joint, make sure its connection type is body-ground and you won't need any other support.
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)-
December 19, 2024 at 11:42 am
SubscriberThanks for the Reply.
When I insert just the joint. ( body ground)
It show a warning that there are no enough boundary conditions and then the simulation stop due to convergence issueÂ
December 19, 2024 at 12:31 pm
Deepak
Ansys EmployeeHi,
Can you please look into this tutorial: How to Simulate Dynamics of a Spinning Yo-yo Using Ansys Mechanical
Thanks,
Deepak
December 19, 2024 at 1:47 pm
SubscriberI took a look on it already before posting here and I checked several posts and video but to be honest I did not find any solution on it to this problem.
As mentionned ealier I tried suggestions for similar problem but not dedicated for this specifically.
Still getting the two warning ( reference convergence value are less then the threshold and the 2nd is not enough constraint. then it will stop due to failure in convergenceÂ
5774
