February 18, 2025 at 10:34 am
Stylianos.Syrigos
SubscriberHi, I am try to extract the parasitics of a layout and when I am running AC RL solutions I am having the following error: disjointed net(s). All sources, sinks have been assigned and all conductors have assigned net names.
Can you please let me know what does this error mean and how may I solve it?Thanks for your help
February 19, 2025 at 8:33 am
Praneeth
Forum ModeratorHi,
Thank you for reaching out to the Ansys learning forum.
Please provide more details to help us identify the cause of the issue. One common solution is to see if you have any unassigned objects in the history tree. If so, please assign them with relevant boundaries or materials or make them non-model and then analyze the model again.
Best regards,
Praneeth,
Click here to join Electronics Community and build a network.
- Ansys Maxwell 3D – eddy current
- Difficulty/Obstacle: “Parasolid entry check failed for part:”
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Maxwell circuit – PWM
- Plotting Ex, Ey and Ez in vector forms individually
- Ansys-MATLAB Co-Simulation
- Compute near field simulation with current
- Y wiring method and the start and end points of winding.
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
- Ansys HFSS, Lumped port impedance affects Z-parameters
1997
897
599
591
444
