September 14, 2021 at 12:19 ammilad.darziSubscriber
How compatible is Ansys Discovery this with Revit?
September 14, 2021 at 5:43 amCharudatta BandgarForum ModeratorHello Milad Are you looking for a comparative study between Autodesk Revit and Discovery? I am not sure if such study is done, I will still check with the team and let you know. You can go through the Discovery capabilities here.
September 14, 2021 at 5:52 ammilad.darziSubscriber
Hi Charudatta Bandgar
Thank you very much for your reply and the capabilities.
I wonder if it's possible to export a geometry/model from Revit in a format that can be used in Ansys Discovery? In other words I would like to know whether Revit files are Ansys-compatible?
I appreciate your comment in advance.
September 14, 2021 at 6:19 amCharudatta BandgarForum Moderator
Milad Apologies for the misunderstanding.
Discovery supports .rvt and .rfa file import. I will still get more information from the team, if anyone has tested it.
Regards.
September 14, 2021 at 6:23 ammilad.darziSubscriber
Charudatta Bandgar Thank you! I look forward to hearing back from you ..
September 14, 2021 at 6:34 amCharudatta BandgarForum Moderator
Milad If you have Revit geometries that you would want to test, you can send it (I will send a secure transfer link in this case), and I can test them faster. I saw you mentioned handling of larger geometries.
September 14, 2021 at 6:42 ammilad.darziSubscriber
Charudatta Bandgar No I don't have a Revit file at this moment. I've been actually trying to address a question that was raised by one of our prospects who are interested in Ansys Discovery. But they want to know how compatible is Discovery this with Revit, since they use Revit for so many of their projects ..
- The topic ‘Discovery vs Revit’ is closed to new replies.
- Unable to attach geometry 2024 R2
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Inventor 2025 files
- SpaceClaim stops sharing topology
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- solidwork parameters for optimization in ansys
1762
635
599
591
366
