March 14, 2023 at 12:50 pm
David Giglio
SubscriberHello:
The client uses Discovery and can use all physics without a problem, except when using CFD physics the program shuts down automatically without giving any warning, error, or message.
He said is drivers are updated. He updated the drivers to the latest version available from Nvidia and that did not solve the issue.
Regarding video hardware, he has the latest GPUs from Nvidia (dual RTX 4090). Each card has 24 gb of video memory.
Please advise.
Thank you!
David A. Giglio, PhD, PEOzen Engineering Inc.
March 15, 2023 at 2:01 am
Subashni Ravichandran
Forum ModeratorHello David Giglio
Is this an issue with a specific CFD simulation model or with all CFD simulations? You could try running one of the Sample models to check this out.
Can you please recreate this issue on client's machine and share the latest application logs?
You can find them at the below location. Please zip and share the latest folder from this location.
C:Users
AppDataLocalTempDiscovery -
March 15, 2023 at 6:17 am
David Giglio
SubscriberHello Subashni:
Thank you for your reply. I have asked the customer to provide the answers to your questions and provide the application logs, and will provide this information to you when the customer responds.
Here I attached the customer's diagnostic folder from the License Management Center, and the logs from the Windows Event Viewer.
Thank you!
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
March 15, 2023 at 1:45 pm
David Giglio
Here are the customer's application logs from C:Users
AppDataLocalTempDiscovery. Please advise.
Thank you!
March 16, 2023 at 8:12 am
Can you please check if this error occurs with one of the sample Fluid simulations?
March 16, 2023 at 9:03 am
David Giglio
The customer has been using the sample models that came with Discovery to check out the functionality.
As a test, he installed Discovery on his laptop (Intel i9 CPU, Nvidia 3080 gpu), and he experienced no issues running the CFD sample models.
Therefore, this appears to be a specific issue with running on his more powerful server (AMD 64-core Threadripper, Nvidia 4090 gpus).
The customer can run Discovery CFD simulation examples in his laptop with no problem. I do not understand how he can run the simulation examples in his laptop but not in his desktop. I just asked if he used a different license file with his laptop installation.
This is the response from the customer:
“For CFD, only Explore is an option. When I select Refine, I get the message “Licenses required to solve: CFD Pro or Higher”. I have included a screenshot below:”
March 16, 2023 at 9:09 am
Refine mode requires CFD Pro + Discovery simulation license.
I'm guessing the customer has Mech Pro + Discovery simulation and is thereby able to run Structural simulations. For CFD simulations in Refine mode, they will need CFD Pro license as well. -
March 16, 2023 at 9:13 am
David Giglio
SubscriberSubashni:
Thank you for your response. So how is the customer able to run Discovery CFD simulations in his laptop then without any problems?
March 16, 2023 at 10:23 am
Devendra Badgujar
Forum ModeratorDavid Giglio
Let us continue our discussion through the SR you created for this issue to avoid miscommunication.
Thanks,
Devendra
- The topic ‘Discovery Shuts Down Automatically without Error or Warning When Using CFD’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
4597
1495
1386
1209
