February 22, 2021 at 3:15 pmGUICADSubscriber
Does Discovery manage hydrostatic simulation ?
Thanks,
Guillaume
February 23, 2021 at 7:49 amNaresh PatreAnsys Employee
Hello GUICAD
In hydrostatic simulation, applied pressure is dependent on the height of water column. In Discovery, you can apply a uniform pressure. So currently it's not possible to perform hydrostatic simulation in Discovery.
July 27, 2023 at 11:57 amRaihan LutfiantoSubscriber
Naresh Patre Hi, is there an alternative way to model the varying hydrostatic pressure? Maybe using script or user defined function?
July 27, 2023 at 4:03 pmRaihan LutfiantoSubscriber
- The topic ‘Discovery – Hydrostatic simulation’ is closed to new replies.
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
599
591
550
366
