April 10, 2026 at 6:57 am
mkrsmanovic
SubscriberI'm trying to simulate what should be a very simple problem: solid body at high temperature immersed in air volume, with air flowing over it. I want to be able to assign a material to the body so I can do a transient simulation and observe how the cooling changes with change of the material. Simple illustration provided below. No matter what I try, Discovery is letting me know about issues, with no guidance on how to resolve it: there is interference, remove interference, remove sharing, conducting non-slip wall assigned a temperature, etc.
Is it even possible to simulate this in Discovery? If yes, how should I set up my model? Thank you.
April 23, 2026 at 9:10 am
Devendra Badgujar
Forum ModeratorHello,Â
Yes, this can be done in Discovery. I would recommend you go through this Conjugate Heat Transfer Using Ansys Discovery Software | Ansys Courses course which will help you solve this.
Let me know if you need further assistance.Â
DevendraÂ
6379
