Directional deformation along a path data export in harmonic response
    • MCK_Pandaleon
      Hello everyone,
      I am studying a piezo transducer in harmonic response and I have multiple questions.
      (1) I want to observe the directional deformation of the superior face of the material. I have created a path (with construction geometry) along which I can easily observe this deformation and export it. However, I am working at a given frequency and I would like to be able to export the same data (deformation along the path) for a full deformation cycle (ANSYS is capable of showing the user the way the surface moves at that frequency but I only have access to a single "moment" of the deformation cycle). I suppose that this information can be accessed since the user is able to "play" an animation of the deformation at any given frequency. I have already tried to create an all sets result but this only gives the deformation at every frequency.
      (2)The question that I am also wondering is if the displacement along the path could have a different phase at each point due to the mechanical losses of the material. So on top of extracting the deformation values for the full cycle (as I explained in (1)); I would also want to have access to the values of the phase at each point for the directional deformation, or maybe even be able to export a table of complex values for the deformation along the path I defined.
      Context : I am working on ANSYS Workbench 2020 R2, I drew half of the system and then defined an axisymmetric symmetry and have a meshing of 4e-4m. I am also working at 200kHz. I choose the harmonic response to simplify the study as much as possible. And I am also using the PiezoandMems extension to define the piezo body of my model which is a simple disc.
    • MCK_Pandaleon
      Update : I have found the macro MAPDL function that produces the animation but I do not know how to get the data it uses. It's the ANHARM macro that uses complex values for the deformation (x = Xre+i*Xim) and I would like to get Xre and Xim along the path for each frame produced by the ANHARM macrofunction.
      Any ideas?
    • Ashish Khemka
      If the Macro has saved the data on the Path then you can plot the items Xre and Xim separately.
      PATH (ansys.com)
      Regards Ashish Khemka
  • The topic ‘Directional deformation along a path data export in harmonic response’ is closed to new replies.
