Difference between particle and DPM variables
    • aniruddhabose96
      Hi
      In the attached picture, is phi inside the summation a particle variable or DPM variable? As far as i understood DPM variables are cell averaged values of particle (lagrangian) variables. Am I correct? This is not very clear in the user guide because there is some mixed terms there.
      What is it being reported on? If it's referring to a number of parcels in a cell it's likely a cell value as a particle value is held on the parcel track.
    • aniruddhabose96
      Yes the result is a cell value but the phi within summation is summed over number of parcels or particles and then the cell value is returned. Is this a correct interpretation?
      Does it give you the value you want to post process?
    • aniruddhabose96
      If the quantity inside the summation is particle variable, then yes. Also I am assuming when you time avg the particle velocity then all the fluctuations becomes zero and we only get the mean vel of particles.
      How are you averaging the particle velocity in the Lagrangian framework?
    • aniruddhabose96
      If you see the above definition, the summation runs from 1 to N parcels or particles. So that automatically averages the particle properties in the lagrangian framework and then wighed by the number of parcels and residence time to give a cell value. Is that correct?
Viewing 6 reply threads
