Ansys Products
Ansys Products
Difference between LS-DYNA and Mechanical solver
    • GDeshmukh02
      Hello guys, Kindly help me with your experience,
      Shall we expect difference between solutions of LS-DYNA and Mechanical solver for the same set of problem(Exactly same)?.
      If yes, then how much should be the difference so that we would know our solution is correct.
      Thanks in advance.
    • armin.abedini
      Hello there,
      Could you describe more about your application employing both Mechanical and LS-DYNA solvers?
      Did you utilize the implicit solver of LS-DYNA for consistency with Mechanical or used the explicit solver?
