June 9, 2023 at 10:02 pm
agranmoe
SubscriberÂ
Hi there,
I am trying to design an evanescent coupler consisting of a linearly tapered GaAs waveguide resting on top of a high-aspect ratio SiN waveguide all buried in SiO2. I would like to use the EME solver so that I can efficiently vary the taper length and save lots of computation time. To verify my EME results, I ran the same setup in FDTD and receive very different transmission results (transmission from GaAs fundamental TE mode to SiN fundamental TE mode). In FDTD, I measure this using the expansion in the output port and in EME I measure this using the S21 scattering matrix element. I will list the various things I have checked in both my simulations below. Please help me figure out why these methods give me such drastically different results, thanks!!
Thanks in advance,
Austin
FDTD:
- Doubled simulation time and increased mesh accuracy from 2 to 3 and get same results.
- Mesh overrides for both waveguides in the Y and Z directions were applied to ensure accuracy.
- No modes are cutoff by PML boundary when looking at mode profiles via ports
EME:Â
- Ran script to verify number of cells in tapered region is sufficient.
- Mode convergence sweep looks normal.
- Checked all diagnostics Lumerical suggests and found no issues apparent to me.
Simulation parameters of interest:
Target wavelength: 950nm
GaAs waveguide dimensions: 250nm wide tapered down to 100nm over 40um, 150nm thick. Refractive index 3.6. Mesh override: dy = 0.04um, dz = 0.02um
SiN waveguide dimensions: 2um wide, 40nm thick. Refractive index 1.943. Mesh override: dz = 0.005um
SiO2 refractive index: 1.4511
June 28, 2023 at 1:10 am
Dev
Ansys EmployeeHello,Â
Please refer to the following:
Why am I seeing a significant difference in coupling efficiency from EME to FDTD? (ansys.com)
Difference in results between FDTD and EME (ansys.com)
- The topic ‘Difference between FDTD and EME results for evanescent waveguide coupler’ is closed to new replies.
