June 17, 2019 at 9:21 am
xavierBAM
SubscriberHello, I was doing some meshing quality control and, when I got to understand what Aspect Ratio and Skewness was, I could get what's the difference between these two parameters. Could anybody explain? Thanks
June 17, 2019 at 10:48 am
Forum ModeratorThey're different ways of working out mesh quality and (generally) serve to check for different problems. What do you think each means?Â
June 17, 2019 at 12:05 pm
xavierBAM
SubscriberIt just looks like they are very similar in the way they value the quality of the mesh. How similar to a perfect triangle and how similar the lengths of the sides are looks too much a like for me. When would you use each one of them?
June 17, 2019 at 12:39 pm
Forum ModeratorAh, OK, you've not quite picked up the maths.Â
Skew is a function of the ratio internal angles against the "perfect angle".Â
Aspect ratio is a ratio of the edge lengths.Â
Look in the help documentation under Meshing and there should be images explaining it. For tri/tet elements a high aspect ratio means high skew: for a quad/hex element high aspect ratio can still have zero skew. Sketch the two shapes (triangle & square) and stretch them then compare to the documentation.Â
- The topic ‘Difference between Aspect Ratio and Skewness’ is closed to new replies.
5899
1306
