Determining the Smallest Cell Size in the Mesh
    • moe9423
      Hope you are all doing well.
      I am doing a transient laminar analysis to simulate pulsatile blood flow
      My fluid domain is a 2d  rectangle with the following dimensions: 3.5 cm (length) & 3 mm (diameter) and the mesh is shown below.
      I am trying to calculate the time step size using the courant number that's why I need to determine the smallest cell size in my mesh.
      Using fluent I tried 'check' mesh and by taking the square root of min area or cubic root of min volume I get cell size equal to 0.0262 m and 7.829*e-3 m respectively  which in both cases sounds unreasonable given that my domain has a diameter of 3e-3.
      Does anyone know how can I determine the smallest cell size in my domain?
      Thank you in advance
      Initial Course Mesh Volume & Area report
    • DrAmine
      As it is 2d the volume will be made by reference depth. Default is one meter if you did not change it under reference values.
    • moe9423
      This makes a lot of sense now.
      Thank you for your help I appreciate it.
  • The topic ‘Determining the Smallest Cell Size in the Mesh’ is closed to new replies.
