January 8, 2018 at 9:54 am
Patrickhe
SubscriberHello guys,
I updated Ansys to 18.2 a month ago. When I transferred my model built in 18.1 to 18.2 and did the design points update, it always got stuck forever at the stage of updating model in static structural of 50% like the picture below.
I tried this model in 18.1 and it worked just fine which took about 2 mins to solve each design point.
I tried clearing the regedit and reinstalling both 18.1 and 18.2 which didn't work.
I tried to rebuild this model in 18.2 which didn't work.
I tried to unmark the distribute solution (picture below) in Mechanics which didn't work either.
I wonder is this a bug in 18.2 or is there something I should change in my system? I am using windows 10 pro x64. Thanks if anyone can help solve this.
January 8, 2018 at 11:00 am
Raef.Kobeissi
SubscriberHello,
Can you please provide additional information about the simulation.
Best Regards
January 8, 2018 at 11:52 am
Patrickhe
Subscriber -
January 8, 2018 at 1:30 pm
peteroznewman
SubscriberI assume you are not on the Student license, but either a Commercial or a Research license since the Solidworks CAD interface is not provided in the Student license. Fortunately, I have the Solidworks CAD interface at work and am willing to test your files if you want.
You would have to create a zip file of the Solidworks files and an Archive of the ANSYS project. Use the Attach button to add the Archive and zip file to your last post. There is a 120 MB file size limit, so work within that by splitting the Solidworks files into two or more zip files (maybe on two posts) if you exceed this value. In ANSYS, clear generated data on the mesh to reduce the size of that archive.
What version of Solidworks are you using?
January 8, 2018 at 1:54 pm
Patrickhe
SubscriberHello,
I am using Solidworks2017 and ansys 18.2 on student license. I'm not sure but I did can work with CAD parameters both in ansys 18.1 and 18.2.
Files have been attached.
Thanks!
January 8, 2018 at 2:27 pm
peteroznewman
SubscriberI downloaded your files and opened them on my Commercial license where I have a Solidworks CAD Interface license for ANSYS. I repaired the file pointer to point to the Solidworks part file and I confirmed that your initial model solved correctly, then I tried to Update All Design Points. I found the Progress stalls on the first CAD update (DP0 and DP1 have no change in CAD parameters) for a really long time (>10 minutes), but eventually, it did update and so did the next one (I deleted the rest of the DPs).
I am also going to get on my other laptop with ANSYS Student 18.2 and test the ability to import Solidworks files (after I install SW2017) as I did not think the SW CAD interface was included in the ANSYS Student license.
January 8, 2018 at 2:54 pm
Patrickhe
SubscriberHello,
Thanks for the quick reply!
Actually if I use the same file which can also be opened in 18.1, 18.1 version will solve in a reasonable time while for 18.2 it seems to take forever.
For me geometry update is ok but it will get stuck in the process of mechanical updating.
What really confuses me is that if i manually change the parameters, then double click to renew and enter the interface of mechanical, then click solve, it in fact works there. However, if i choose to right click on model and update, it will get stuck there.
January 8, 2018 at 4:04 pm
peteroznewman
SubscriberThere is definitely a bug in ANSYS 18.2 that creates a huge delay (>30 minutes) in an update from SW through DM to Mechanical. I will create a simple model and submit that bug to my local ANSYS support people who will verify it is reproducible then forward it on to ANSYS developers. You should stay in 18.1 for now...
January 8, 2018 at 4:08 pm
Patrickhe
SubscriberAll right then, thanks!
January 8, 2018 at 5:09 pm
peteroznewman
SubscriberI made a simple solid model with two Design Parameters and the Parameter Set solved without huge delays so I was unable to reproduce the problem on your files. My files are in the attached zip file if you want to try it on your system.
January 8, 2018 at 6:05 pm
Patrickhe
Subscriberwow Great! Thank you!
April 4, 2018 at 5:53 am
saurabh156
SubscriberHello everyone. I m running Parametric optimization on ANSYS Workbench using VisualDOC optimizer by Van der plaats.Â
When the design iterations are running, they are properly simulated by ANSYS for a few iterations. But Fluent stops working after a while. It pauses the simulation. I m not sure what the problem is. Any help will be appreciated.Â
May 12, 2018 at 10:17 pm
saurabh156
SubscriberHello Raef and Peter,Â
I m really stuck at a problem. Can you please help me with it. I have posted my question above.Â
Thank you.
- The topic ‘Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural’ is closed to new replies.
5879
1306
