June 13, 2023 at 7:46 pm
javat33489
SubscriberI'm simulating SPH drilling of sandstone particles using Mohr Coulomb in WB LS-Dyna ACT.
Drill - rigid body.
Nozzles on the drill are deformable.
Steel properties:
Sandstone properties:
Why do my baits bend so much? They are much harder than sandstone. Drilling does not occur:
Calculation time 0.001 s.
I am using Displacement:
Rotate 180 degrees and move 5 mm.
June 14, 2023 at 12:38 pm
Ram Gopisetti
Ansys EmployeeHi javat,Â
rethink the material model for sandstone with some failure criteria , read the paper title "Numerical simulation of impact on pneumatic DTH hammer percussive drilling " by Changgen Bu et.al .
cheers RamÂ
June 15, 2023 at 6:46 pm
javat33489
SubscriberI read, thank you what I need.
BUT I can't add that kind of stuff to Dyna ACT WB.
1. I tried to add a MAT_JOHNSON-HOLMQUIST_CONCRETE snippet and PART card to link the rock to be drilled to the material, but the workbench gives me errors:
Then I decided to add a section map, it didn't help either:
How to add material snippet to Dyna ACT WB?
I have a rigid drill. Rock / blank - sph - I want to assign the material to it through the map:
2. Then I decided to add material to DYNE Prepost. And the calculation did not work again, the following error appears:
But with a simple plastic material he thinks
June 16, 2023 at 8:23 pm
javat33489
SubscriberI figured out the LS Dina ACT.
The material snippet needs to be inserted into the geometry and not into the solver.
BUT the material still does not work. When inserting a snippet:
writes an error:
If you insert without a TITLE, then the calculation does not start.
But the LS-Dine postprocessor (black) still does not work. Error above.
- The topic ‘Deformation of steel on sandstone in WB LS-Dyna ACT.’ is closed to new replies.
4934
1639
1386
1242
