Defining variable fluid inlet temperature in Fluent
    • Yogesh Sajikumar Pai
      Hello all,
      I'm running a transient simulation in Fluent and I want to define a non-constant fluid inlet temperature.
      My inlet temperature depends on the temperature of a cell zone and I know what the inlet temperature should be at different temperatures of that cell zone. I need Fluent to interpolate the inlet temperature between the ranges and not change abruptly (which I could even do manually).
      For example,
      At 650°C of cell zone, inlet temperature = 100°C,
      At 600°C of cell zone, inlet temperature = 80°C,
      At 500!C of cell zone, inlet temperature = 55°C,
      ...and so on.
      Thank you!
    • SRP
      I recommend creating a UDF for inlet temperature.
      For more details, please refer to fluent customization manual: 1.3. Defining Your UDF Using DEFINE Macros (ansys.com)
      If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
      Thank you
      Saurabh
  • The topic ‘Defining variable fluid inlet temperature in Fluent’ is closed to new replies.
