Defining iso-surface in a different orientation other than x, y and z
    • vguda
      I have a cylinder with the inlet face oriented in YZ direction. The length is along X direction. Say this cylinder is now rotated about Y direction 50 deg. I want to create an iso surface in the center plane along the length in the new axes. How to do it.
      If the cylinder is in regular orientation, i can say create iso surface in constant z . Now since it is rotated how to do it?
      If the geometry has parts oriented in different directions, is there a way to create one iso-surface or plane to represent the entire geom to view the flow
    • raul.raghav
      Moving this to the “Result Visualisation” thread.
      You can create a plane by prescribing 3 points. So a cross-section normal to the Z-axis of your original cylinder can be created by prescribing 3 points:
      (i) 0, 0, 0
      (ii) 0, y, 0
      (iii) x, 0, 0
      Now if you rotate the cylinder along the Y-axis by 50deg, the 3 points required to create the mid-plane normal to the Z-axis would become:
      (i) 0, 0, 0
      (ii) 0, y*cos(50), 0
      (iii) x, 0, 0
      Is this what you’re looking for?
    • Keyur Kanade
      hello,
      Here is the procedure. Hope it helps.
      Keyur
  • The topic ‘Defining iso-surface in a different orientation other than x, y and z’ is closed to new replies.
