January 7, 2022 at 7:10 pm
gurkanonal
SubscriberAs you may know, Young's modulus of a CFRP material which is subjected to tension, is different than in the case of compression. See the reference [1], [2] and [3]. For example, the material "AS4 12k/938" has Young's moduli of 154 GPa in tension, 125 GPa in compression [1].
As far as i know, Cast iron model does not allow to have different Young's modulus tension and compression. Under these circumstances, how we define a material such that through ANSYS Workbench?
References:
[1] https://doi.org/10.1016/j.compstruct.2015.02.064
[2] https://doi.org/10.1016/j.compstruct.2011.09.018
[3] DOI:Â 10.1016/j.ijimpeng.2016.05.002
January 10, 2022 at 2:55 amDavid Mercier
Ansys EmployeeHi, I think you should script it with Ansys APDL maybe, and you may find some tips and answers in previous posts on the forum:
/forum/discussion/22576/how-to-define-different-relation-in-compression-and-tension-for-steel-material
/forum/discussion/8250/different-youngs-modulus-in-compression-and-tension
/forum/discussion/1411/different-young-moduli-in-tension-and-compression
/forum/discussion/8611/model-with-different-elastic-moduli-in-compression-and-tension-and-x-y-z-direction-with-ansia-apdl
And this post also on cast iron contains some tutorials: /forum/discussion/7378/cast-iron-model
Viewing 1 reply thread- The topic ‘Defining different Young’s modulus (stiffness) in tension and compression’ is closed to new replies.
