TAGGED: ansys-fluent-meshing, boundary-conditions, meshing
June 25, 2026 at 7:07 pm
megm07
SubscriberHello! I'm looking to set up a particle deposition simulation in Fluent. The CAD (image below) has an opening at the top and bottom where the inlet and outlet are supposed to be, but I'm having trouble moving past the meshing step because it won't recognize the top opening as an inlet. Both openings are made of two edges. When I use the two edges to make named selections of "inlet" and "outlet", meshing doesn't recognize them as inlet & outlet to then set up the fluid zone (which would be the empty space in the middle). When I created a surface using the edges and then defined the faces as inlet and outlet, Fluent meshing ran into an error when capping the enclosed fluid region saying
"A cap could not be created using the specified zone/label. Ensure your zone/label encloses the whole opening.
Error Object: #f"
Any help would be much appreciated! I can also provide more info about the system as necessary.
June 26, 2026 at 7:30 am
NickFL
SubscriberThere are several ways of doing this. Let us try by creating capping surfaces and then using the fill to get the fluid volume. Only then can we define the inlet and outlet.
11) Grab the one or two lines that are at the circumference of the inner circle. Then under the Concept pull-down menu select “Surfaces from Edges” and click Apply and Generate. This should create a surface body across the top.
2) Do the same thing on the bottom, covering the outlet.
3) Now from the Tools pull-down menu select “Fill”. Here in the Details panel you will want to change the “Extraction type” from “By Cavity” to “By Caps”. Click Generate and it should create your fluid volume.
June 26, 2026 at 8:11 pm
megm07
SubscriberThanks so much! The fill tool was able to create a fluid body in between. If I've done this step, do I still have to define the geometry in Fluent Meshing as having a void / needing to enclose a fluid region, or can I just proceed without extracting a fluid region again?
6765
1330
1127
