LS Dyna
LS Dyna
DEFINE_BOX map does not work
    • javat33489
      Hello everyone, in LS-Dyna 2024 I use the BOX map.
      I do a calculation with particles and they fly apart a lot, I want to limit the calculation resource only to the desired area.
      I install the map but it always shows an error. Why? Thank you.
    • Alex Rycman
      Please look at the definitions of the parameters:
      In the model that XMN (80) is greater than XMX (-80), YMN> YMAX and ZMN > ZMX. Please switch the coordinates so the box is defined with a positive volume.
      Thank you,
      Alex
