December 13, 2021 at 1:21 pm
marin.delacroix
Subscriber? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHi, Mode explore : I'm trying to define a displacement in a local CS but I get the following message : "translational displacement must be defined with displacements in the global directions only". This message disappears if I constrain a second DOF, but this over constraints my model and this is not the BC I want. This is however a very basic thing. Did I miss something ? Please find attached a video that illustrates that -
December 13, 2021 at 2:16 pm
Devendra Badgujar
Forum ModeratorHello Marin DE LA CROIX I tried the same steps as you did in the video to define displacement in a local CS but did not got the message that you received. I have attached the video for your reference. Please can you try closing this session and starting new from scratch, see if it solves the issue. Regards.? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
December 15, 2021 at 11:43 am
marin.delacroix
SubscriberHi Devendra, In your example, the local CS matches with the global CS. The behavior I got happens as soon as the selected direction does not match with a global direction. Please have a look at the attached video, as well as the model. Marin? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
December 15, 2021 at 1:39 pm
Devendra Badgujar
Forum ModeratorHi Marin DE LA CROIX
I was able to reproduce the issue in Explore mode. Refine mode does not give this error though.
Let me check and get back to you on this.Â
December 16, 2021 at 6:11 am
Devendra Badgujar
Currently in explore mode, defining displacement in Local CS is not supported yet. Only those matching with global directions are supported. You have to go back calculate global coordinates.
Regards.
Viewing 4 reply threads
- The topic ‘Define displacement in local CS’ is closed to new replies.
