November 20, 2025 at 3:08 am
November 20, 2025 at 8:20 am
Nanda
Ansys EmployeeHello User,
You should assign a boundary condition to the supports (*BOUNDARY_SPC). If it is fixed, then constrain all DOFs. In LS-DYNA, to extract reaction forces at a support defined by *BOUNDARY_SPC, the reaction forces are typically output using the *DATABASE_SPCFORC command, which creates an SPCFORC file containing the reaction forces at the nodes where the boundary conditions are applied.Hope this helps.
Nanda.
Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
Have a look at our public help documentation website: Ansys Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
November 26, 2025 at 3:33 am
1373620234
Subscriber谢谢你 我应该使用*BOUNDARY_SPC下面的哪个卡片
November 26, 2025 at 1:27 pm
Nanda
You can use *BOUNDARY_SPC_NODE_SET, create a node set for all the supports you have. Under card1, assign the created NSID, and constrain your DOFs accordingly. DOFX, DOFY, and DOFZ are translational DOFs. DOFRX, DOFRY, and DOFRZ are rotational DOFs.
Nanda.
4377
1494
1375
1203
