December 2, 2024 at 2:22 pm
marco.goesling
SubscriberHello, I try to model concrete. I test the material model mat084: Winfrith.
When I open the d3crack file then I get the messagae:
not validI have tried it with training-examples and downloaded demo-examples, alwaysthe same message.
I use Solver R12.0 on a Windows64 machine. I start the file with LS-Run1.0 with adding Q=d3crack. I do postprocessing by LS.PrePost 4.7
Where is my mistake. Can anyone help?
December 3, 2024 at 4:25 pm
igandiko
Ansys EmployeeHello, are you opening d3crack file directly in LSPP? You may have to load the d3plot database first and then select File > Open > Crack file to open the binary crack database.Â
(or) you can open the database using the execution command below,
lsprepost d3plot q=d3crack
Please use the latest LSPP build (4.7 is quite old).Â
December 4, 2024 at 1:18 pm
marco.goesling
SubscriberHi, thankyou for your answer.
first I load the d3plot and then the crackfile by File/open/Others/Crackfile.
I tried your advice to open both files by execution comand.
I have also updated LSPP (to 4.11.12).
Unfortunately, nether of these helped.
