July 4, 2024 at 5:52 am
pavan kumar
SubscriberHelloÂ
I am doing cyclic symmerty simulation in static structuralÂ
below is the model
and i defined frictional and bonded contact below is the image of modelÂ
below image shows the boundary conditionÂ
and loading is shown belowÂ
i am getting the error like mentioned belowÂ
*** ERROR ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â 8695.516Â Â TIME= 20:49:04
 Solution not converged at time 1.666666667E-02 (load step 1 substep 1).Â
can anyone help me to slove this problemÂÂÂÂThanksÂÂ
July 4, 2024 at 5:56 am
July 5, 2024 at 10:19 am
peteroznewman
SubscriberHello Pavan,
Always insert a Contact Tool under the Connections folder and Generate Initial Contact Status whenever you have Frictional contact.
It may be that the contact is Open and that is the cause of the failure to converge. Please show the table of Initial Contact Status.
I suggest you first convert the Frictional contact to Bonded contact, turn off Large Deflection and try to solve. Does that work? If so, turn Large Deflection back on and try to solve. Does that work?
Peter
July 10, 2024 at 4:08 am
July 10, 2024 at 4:12 am
pavan kumar
SubscriberHello peteroznewman
Yes I did this
i changed from Frictional contact to Bonded contact, i turned off Large Deflection and this is worked without any error
July 10, 2024 at 4:15 am
pavan kumar
Yes i did thisÂ
i changed this from Frictional contact to Bonded contact, i turned off Large Deflection and this is worked without any errorÂ
- The topic ‘Cyclic symmerty’ is closed to new replies.
5664
1890
1419
1304
