Ansys Products
Ansys Products
cx2010.exe has stopped working
    • souperman1985
      Hi everyone,nWhile running a straightforward 8-million mesh element simulation (tube inside a big box, k-epsilon, radiation and energy) we experienced a computer crash. Thereafter, upon starting Fluent we continue to receive an error that says cx2010.exe has stopped working. As suggested (/forum/discussion/4598/fluent-cx1920-exe-doesnt-work-anymore) and (/forum/discussion/18433/cx2010-exe-not-responding) we have changed our graphics card settings. We have also reinstalled Fluent. The problem remains. Any ideas?nThanks!n
    • ANSYS_MMadore
      Can you try renaming each of these directories by adding a .old and see if there's any difference?
      %USERPROFILE%.fluentconf
      %APPDATA%Ansysv201
      Thank you,
      Matt
    • souperman1985
      Hi Matt,
      Sorry about my delayed response.
      We were able to find and rename the following:
      C:Users{USERNAME}AppDataRoamingAnsysv201.old
      C:Users{USERNAME}AppDataLocalAnsysv201.old
      However we could not find the ".fluentconf" file. Is there another name it might have?
      Anyhow, now we are experiencing licensing errors - something about tomcat not starting. I'm not sure if it's related though.
      Thanks!
    • tsiriaks
      Tomcat is used only for ANSYS License Management Center (not even for ANSYS License Manager) , so client machine shouldn't see any error related to Tomcat. Can you post the screenshot of the error and describe what to do to get to this point of error ?
      As for the original issue, do you get this issue from stand-alone Fluent as well ?
    • Sonic_Boom
      souperman1985 have you found the solution to the cx2010.exe stopped working? If yes then pls let me know
      mmadore pls advise too
      I have attached the screenshot of the same; image 1 is the screenshot before the cx2010.exe stopping error and image 2 is the ANSYS FLUENT error after the cx2010.exe stopping error
      Any inputs from others are also appreciated, kindly help.
      Sainath. B
      Image 1--->
      Image 2--->
    • ANSYS_MMadore
      Sonic_Boom Are you running on a VPN?
    • Sonic_Boom
      No mmadore
    • ANSYS_MMadore
      Is this the Student version or a paid version?
    • Sonic_Boom
      Student mmadore
    • ANSYS_MMadore
      Are you able to try a newer version of Ansys Student?
    • Sonic_Boom
      no mmadore
    • ANSYS_MMadore
      1) Please open a Windows command prompt and run the command "dxdiag" and send post screenshots inline in a reply.
      2) Please try disabling your firewall to see if that changes the behavior
      3) On the Fluent Launcher, on the Parallel Settings tab, please select MPI Type of 'msmpi' and click the box for 'Select IP Interface' and select '127.0.0.1' from the dropdown.
Viewing 11 reply threads
  • The topic ‘cx2010.exe has stopped working’ is closed to new replies.
