January 8, 2024 at 1:45 pm
Giorgos Troulliotis
SubscriberDear all,
I am working on cardiac simulations and I have implemented a subroutine which couples a custom 0D CV model to an FEM model of the heart. The segregated coupling is centered around minimising a residual function.Â
I would like for the implicit solution to move to the next timestep once the coupling residuals have reached a certain threshold in addition to the standard displacement and energy residuals converging.
Currently, I am forcing convergence after a fixed amount of iterations. This produces reasonable convergence, however it's quite inefficient and the degree of convergence varies during the cardiac cycle.Â
Is there any way to create a custom convergence criterion, or control solver convergence outside of the keyword *CONTROL_IMPLICIT_SOLUTION?
Many Thanks  Â
January 10, 2024 at 9:18 pm
Reno Genest
Ansys EmployeeHello George,
If I understand correctly, currently, you are using the default implicit convergence criteria in LS-DYNA and force convergence after a fixed amount of iterations correct? Then, you check your residual function and it is low enough after the fixed amount of iteration so that you can say convergence was reached correct? But, you would like to implement a custom convergence criteria based on your residual functions? Do I understand correctly?
Reno.
January 10, 2024 at 9:27 pm
Giorgos Troulliotis
SubscriberHi Reno,
That is correct I have found that 10-15 iterations works for most timesteps in the cycle however, some timesteps require less and some more. I would like to automate the process for efficient solution and control over the coupling convergence.
Best Regards,
George
January 11, 2024 at 10:13 pm
Reno Genest
Ok, let me check with the developer and get back to you.
Reno.
March 12, 2024 at 2:21 pm
Giorgos Troulliotis
SubscriberHi Reno,
Have you had heard back form the developers regarding this query?
Best Regards,
George
March 12, 2024 at 4:43 pm
Reno Genest
I haven't heard yet. I just followed up with him. I'll let you know when I hear from him.
Reno.
- The topic ‘Custom Implicit Convergence Criteria’ is closed to new replies.
5939
1307
