October 4, 2024 at 10:22 am
yasmine.sichaib
SubscriberHello,
I am currently working in maxwell with two conductors that have a surface of contact. These two conductors are made of different materials and therefore maxwell computes two paths of current instead of one. Thus, when I apply a current in the entry of the first conductor and another in the exit of the second I get an error saying:
'In one solid conduction path, at least two external currents should be specified'
Do you know how I can 'impose' a contact between them for maxwell to understand only one path of current ?
ThanksÂ
November 15, 2024 at 2:44 pm
Timos
Ansys EmployeeHello, to impose a contact between the two materials and have Maxwell understand it as a single path of current, you may need to create a terminal (sheet object) that matches the cross-section of the conductor at the desired location for the contact. This terminal can then be used to apply the excitation (current/voltage) across the contact surface.
5824
