TAGGED: boiling, cryogenic, fluent, heat-transfer, multiphase
December 20, 2021 at 6:12 am
matus
SubscriberHi
I am interested in simulating a pipe placed in a liquid nitrogen bath.
I need to find the temperature and stress distribution on the pipe surface over time. How should I start my simulation? Which model do I need to use? Can I solve this problem using a transient thermal module instead of a fluent simulation?
Can I assume some constant value of heat transfer coefficient at the solid-liquid interface?
Thank you.
December 20, 2021 at 3:54 pmRK
Ansys EmployeeHello,
Which software are you using?
December 21, 2021 at 5:07 ammatus
SubscriberANSYS WORKBENCH 2020 R1.
I have fluent and transient thermal modules.
December 21, 2021 at 3:00 pmRob
Forum ModeratorIf you need the flow field you can do all of the flow and thermal calculations in Fluent. Then pass the solid temperature back to Mechanical. If you're not worried about the flow, you can estimate a surface heat transfer coefficient and run it all in Mechanical.
December 27, 2021 at 4:25 ammatus
SubscriberThank you.
Viewing 4 reply threads- The topic ‘Cryogenic Cooling simulation’ is closed to new replies.
6369
