November 6, 2024 at 4:58 pm
sport052
SubscriberI had an unsuccessful installation after downloading and extracting the .zip folder for ansys student and once I removed the partial installation and tried a second download its result was a critical error: "uninsta.dat file not found." I have since tried fully deleting the ANSYSinc files from my computer and re-extracting the files from the .zip but unfortunately, I am still faced with the critical error once I run the setup.exe file (yes I did use "run as administrator"). Please let me know if I am missing something key in order to successfully download this app.
Thank you
November 7, 2024 at 9:16 am
Rajeshwari Jadhav
Forum ModeratorHi,
Could you provide the contents of this file? If it shows a size of 0kb, try deleting it and then run your install again.
%appdata%\Ansys\v242\ProdConfig
Follow ERROR- “File not found: uninst_data.dat” and “File not found: uninst_data.dat”
November 21, 2024 at 10:12 pm
November 22, 2024 at 1:12 pm
Rajeshwari Jadhav
Forum ModeratorHi,
Your installation is incorrect, you should have more folders. For me it's about 41 items.
Please re-install the application with admin access.
6119
