May 7, 2021 at 12:19 pm
Ansyshs
SubscriberHello,
Please i need your help !!
I have a bolt connection from stainless steel( the bolt with pre-load) and i want to use Chboche and a creep model ( i am using modified time hardening). i have a good fitting for chaboche and for the creep curve !! . I didn't get any solution and i don't know what is the problem.
could you help please. i would be grateful for your answer.
May 13, 2021 at 8:42 pmJohn Doyle
Ansys EmployeeIt looks like you are trying to perform a restart at LS1 with an endtime of 1e-6 seconds. Beyond that, I am not able to tell what the problem is. What is the solver output reporting about the failed convergence?
Regards John
May 14, 2021 at 8:23 amAnsyshs
SubscriberHello John thank u for ur answer. The problem is that no results . Ansys remained at 20% progress for a long time . if i leave , it may solving for a an hour or more !!
May 14, 2021 at 8:25 amAnsyshs
Subscriberi have tried Time hardening and modified time hardening . the same thing !! no results and 1 % for a long timeMay 14, 2021 at 6:39 pmJohn Doyle
Ansys EmployeeSo there is no solver output at all? It sound like a remote connection issue, but I might be misunderstanding what you are reporting.
Two questions:
When you highlight Solution Information and Solver Output (in details window of Solution information) do you see anything or is it a blank page? If blank page, then it sounds like nothing is being set to the MAPDL solver and perhaps there is some kind of remote connection issue. If you do have something recording in the solver output, what is it saying?
Is this happening only when you introduce nonlinear materials? Does a simple linear elastic test model run to completion successfully?
May 14, 2021 at 7:02 pmMay 14, 2021 at 7:02 pmAnsyshs
SubscriberIt is till this time 1 %May 14, 2021 at 7:12 pmJohn Doyle
Ansys EmployeeThere is nothing in this solver output that suggests plasticity or creep are the cause of nonconvergence.
I am still not clear about question 2. What happens when you suppress the nonlinear materials? Does it not converge?
The convergence tread on force residual actually looks very good. I do not know why it is taking so long.
May 14, 2021 at 7:19 pmMay 14, 2021 at 7:28 pmMay 19, 2021 at 6:33 pmAnsyshs
SubscriberI hope you could have some time sir..it's so important :(May 20, 2021 at 1:05 pmJohn Doyle
Ansys EmployeeSorry for the delay. Thanks for the feedback.
The error message "...creep integration algorithm does not converge..." suggests that the creep strain that is calculated for the elements referenced cannot be reconciled with the stress state that the model is in. It is probably a very large number. If you turn off all the nonlinearities in the model and just run this with the loads as defined, does the model converge? If it does, can you take the stress result at one of the elements referred in the error messages and do a hand calculation to predict the expected creep strain for a given time increment? That might give you some insight as to what the code is struggling with. If your hand calc of creep strain is very high because the peak stress is very high, you need to change something. Are the stress values real or fictitious? I see some sharp corners. Also, is there temperature dependency in the model. Keep in mind that we linearly interpolate the creep coefficients between temperature values and this linear interpolation is not always appropriate. I am not sure if that is an issue here or not, but it might be something that needs to be investigated. There is a way to switch to a logarithmic interpolation with the TBIN command. It can be done in WB with a command object if it appears to be necessary. I hope this helps.
Viewing 11 reply threads- The topic ‘Creep+Chaboche Model’ is closed to new replies.
Innovation SpaceTrending discussions- LPBF Simulation of dissimilar materials in ANSYS mechanical (Thermal Transient)
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
Top Contributors-
4167
1487
1363
1194
