TAGGED: expression, fluent, material-properties, udf, viscosity
December 21, 2022 at 12:46 pm
m_gonser
SubscriberHello together,Â
i am struggling to define the dynamic viscosity of my fluid in the material properties settings in Fluent.
I received the temperature dependent density and temperature dependent kinematic viscosity of a fluid. Both are given as a polynominal function. As i cannot enter the kinematic viscosity properties of the fluid directly, i want to create a new expression for the dynamic viscosity (Density*Kinematic Viscosity)The equation is as followed:
(A0 [kg/m^3] * StaticTemperature * StaticTemperature * 1 [K^-2]
+ A1 [kg/m^3] * StaticTemperature * 1 [K^-1]
+ A2[kg/m^3])*(B0 [m^2*s^-1]*StaticTemperature^6*1[K^-6]
- B1[m^2*s^-1]*StaticTemperature^5*1[K^-5]
+ B2[m^2*s^-1]*StaticTemperature^4*1[K^-4]
- B3 [m^2*s^-1]*StaticTemperature^3*1[K^-3]
+ B4 [m^2*s^-1]*StaticTemperature^2*1[K^-2]
- B5 [m^2*s^-1]*StaticTemperature*1[K^-1]
+ B6[m^2*s^-1])Â
I Also tried to create a new named expression to define the kinematic vicosity with StaticTemperature as variable. But i always get the error "Expression is invalid in current model setup"
I defined the density as a polynomial function already.
I do not have a lot of experience in Fluent and hope one of you guys can help me out here.
Thank you already!
December 22, 2022 at 10:02 am
SRP
Ansys EmployeeÂ
To learn more about expressions, please check the user's guide.: 5.1. Introduction to Expressions (ansys.com)
If you are unable to access the link, follow this forum discussion /forum/forums/topic/using-help-with-links/#latest
Thank you
Saurabh
- The topic ‘Creating Temperature Dependent Material Properties with Expression in Fluent’ is closed to new replies.
6545
1311
