Creating streamline issue
    • pavankonchada123
      Hi Team,
             Is there a tui command to create one stream line from inlet to outlet , for plotting the graph between velocity(y -axis) and length of streamline (x-axis)
    • DrAmine
      You can do that by using mass less particles and just inject single stream. Once it is there you can plot along it.
    • pavankonchada123
      just to reframe the question I have 5 outlets and wanted to plot velocity on stream lines starting from inlet to outlet1, outlet2, outlet3....outlet5. So total 5 streamlines with 5velocity plots
    • DrAmine
      You can create the pathlines in Ansys Fluent and use the option "Reverse". There select the outlet(s) as source(s) for the pathlines.
  • The topic ‘Creating streamline issue’ is closed to new replies.
