Creating Animation from cas and dat files
    • Kunal Chopra
      I have around 75 cas and dat files and my workbench got shut down but the files are saved. They were saved in a temp folder in .h5 format. How do I create timestep animations from those files as I can only read/import 1 file at a time in post and solution?
      Copy those files somewhere safe - if you open the wrong part of Workbench you may lose the temp folder.  Using Fluent in standalone mode (Start menu) I would tend to write a journal to read case & data create image, write image, read next case & data, repeat. CFD Post in standalone mode won't (I think) read the h5 format otherwise you can usually read all data sets in at once; Ensight may work but it's not a tool I use at present.
  • The topic ‘Creating Animation from cas and dat files’ is closed to new replies.
