March 27, 2020 at 1:53 am
Dilini
SubscriberHello,
I want a plot of total pressure along the center-line of a selected surface. For that when I try the XY plot in Fluent results, I can only choose a surface as my x axis but not a line. How can I get this done?Â
(For this I am not using CFD post since the pressure values the CFD post gives are static values as I know. If it is possible to get what I want from CFD post let me know. I want the total pressures)
March 27, 2020 at 4:59 am
Keyur Kanade
Ansys Employeeyou should be able to select a line.Â
how are you creating a line? use results - create - line.Â
for range, you can use axes option.Â
in cfdpost you can add static and dynamic pressure and create a new variable to plot.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘Creating a XY plot for total pressure with x axis as the center line of a surface’ is closed to new replies.
6515
