TAGGED: dpm, multi-component-mixture, particle-injection
March 20, 2023 at 5:18 pm
gloria.gonzalez
SubscriberI am trying to create an injection of multicomponent particles and I am having trouble when setting the materials these particles are made of. I am defining the needed materials and trying to add them into the particle-mixture species (following the instructions of the Fluent User’s Guide). However, they do not appear as available. In the tab components (when setting the injection properties) only water appears as a component (although other fluid materials that I have defined appear in the evaporating species dropdown). How can I create a multicomponent particle made of, at least, two materials (different from water)?
Any reply will be appreciated. Thank you in advance!
March 21, 2023 at 7:51 am
SRP
Ansys EmployeeHi,
I suggest you please check previous forum discussion: Creating a new particle mixture template by editing the material database file in fluent (ansys.com)
Hope you find this useful.
Thank you
- The topic ‘Creating a multicomponent particle (DPM)’ is closed to new replies.
6745
1324
1047
