November 29, 2023 at 1:37 pm
christoph.graf
SubscriberHello,
I am trying to create a number of report definitions from a journal file. For most fields this works fine, however I run into a problem for the temperature report. I ue the following command:
(ti-menu-load-string (format #f "solve report-definitions add temp01 surface-areaavg surface-names z=0.1 () field gas temperature" ))
This creates a report definition but it is still invalid. When I open it in the GUI under the "field names" section the upper drop down has "Temperature" selected, while the lower drop down is empty. How can I select "Static temperature" from the TUI?
Thanks for the help.
November 29, 2023 at 4:29 pm
Federico
Ansys EmployeeHello Chris,
why do you have the word "gas" before temperature? Removing this should create the corresponding report for Static temperature.
November 29, 2023 at 4:35 pm
christoph.graf
SubscriberMy case is using multiphase DDPM model so I need to specify the phase. I have two phases named "gas" and "solid".
November 29, 2023 at 6:46 pm
Federico
Ansys EmployeeSorry I misunderstood. It seems from testing the TUI command that Temperature is only available for the mixture, but not for the phases individually
- The topic ‘Create temperature report from tui’ is closed to new replies.
5794
